06 56 series sheetmetal
awchevy
Can someone clarify if the 06 series tin is the same as the 56 series? Are any of them wider or longer? Thanks for the info.
Well the biggest thing on a hood is the air cleaner exit, the 1206 was much bigger opening than the 806, where they had those louvers,[that was strictly cosmetic] and the 856 diesel had a two stage filter, and that two would fit under the hood, on a 806 diesel, but pretty tight changing the primary filter, Grab a tape measure and go shopping !!
Now that i think of it the 1206 and 1256 exited on the left side of the tractor, the the 8's were the right side!Pretty sure they are the same width!!
The 1206/1256 have the exaust and intake screen on the right. The air cleaner access is on the left.I know this cause I been sitting on it today.
Thanks. That's the info I needed. Someone said they had different widths but from what I all saw was the same. How much longer is the 1456 versus the 12?
