hydraulic leaks
oldstoner
I have a 1956 300 utility which has hydraulic oil leaks at the operating lever for 3-point and the other two levers. How can I repair these? Are there o-rings or seals at the lever bases or what! Thanks OLD STONER!
Hey OLD STONER I've always told my kids that if you dont know how it works take it apart carefully and you will know. Try to locate a repair manual, perhaps someone on this forum may have some info. You may have worn o-rings worn parts. Al71
I have a Farmall 300 and I think the valves are the same. The valves have O-rings between the valves which leaked a lot when I first bought my 300. I also ended up overhauling the valves. Most everything in them also are O-rings. Best thing to do is get the covers off the valves so you can see the valves, clean them up good and as you use it, watch for where the leaks are coming from.
