IAtractorKid
Hey guys. So with all the snow and wind we just got,
I've been out plowing a lot. Sunday I noticed the
606 I've been using has developed a knock. Its only
there once engine is up to temperature, and only in
the 1200-1800 rpm range. Anything under or above
that and it sounds just fine. Had been starting and
running great prior to this...any ideas or where to
start?
On a side note, I don't know if it would be related
but I got the tractor stuck Sunday night. Had to
leave it sit out overnight until the neighbor could
come help me. That next morning I had a heck of a
time getting it started and once I did, it was
running rough. I got it back to the garage and shut
it down. Did some checking at that time, plugs were
wet and two were oily. I cleaned them, regaped and
put back in (has Autolite 386 now...thought about
swapping to 388). Also cleaned up the inside of
distributor cap and rotor as they didn't look the
best. Don't know if the rough running was from being
cold and having flooded it, or related to the
knock???
start?
knock???
