Adding a remote to Super C and also, speeding up the hydraul
Schultz
Is there any way to add a remote to a super C. I'd like to put a power angle cylinder on my snowplow. Also, I have an original IH snowplow on it operated by the touch control rockshaft and was wondering if there was any way to "speed up" the hydraulics. Mainly just in the down position of the blade. Same with the fast hitch too. goes up pretty fast but down quite slow.
Thanks
Change out the oil from 90w Hi Trans to power steering fluid. The hydraulic oil IH used was about the same as light weight power steering fluid. The front rock shaft was so responsive it could be used to shake dirt and trash from the front gangs.
http://www.ebay.com/itm/Hydraulic-By-pass-bypass-block-for-Farmall-Super-A-C-Super-C-/301501510352?pt=LH_DefaultDomain_0&hash=item4632e3f2d0
no connection to seller, but this is the common way to do it.
other option, look for an oem valve and lever for the fast hitch.
I looked at that on ebay but noted that it said No Fasthitch. I have a fast hitch on this tractor
Fast itch is supposed to go down slow the junction at the base of the seat support has a slow down devise there so if you want fast down remove it.Easy way to add another control is put a control valve in the pressure side coming from the pump make sure its an open center and put it in series then you can run another cycl.
There is a "bypass block" that bolts between the touch control block and the hydraulic lines, which allows you to add as many remotes to the tractor as you want.
Normally it is used with the regular hydraulic lines. I am not sure if it will work with the fast hitch valve.
You could block the fast hitch in a fixed position and use its valve to control a hydraulic angle on the blade.
