Parts for Farmall 400 spin out wheels
Hi all,
I have a desire to go from the regular style of wheels and rims (15.5 x 38's) to spin out wheels and rims.
What all do I need to do this? Will rims from a 460 work for this application? Any good idea who to call for these parts?
Thanks
Chuck
I have a set on a 450. You can buy new rims. The trick will be finding the hubs. I measured a 460 axle once and it has the same diameter as M-450 so it should work. 560 is the same too.
Where are you lacated? I have a pair of rollout rims and hubs Complete on a 560 parts tractor. Rims appear to be ok.I am located half way between Dayton and lima ohio.
There's two different axle sizes on 460's. Some have 2-1/2 inch, same as H/SH/300/350. Others have 2-3/4 inch, same as M/SM/SM-TA/400/450/560/656/666/686/H86/544/etc.
Same with the 300 & 350, heavy-duty axle option was 2-3/4" over the 2-1/2 inch.
My 300/350 parts book, TC-54A dated 2-15-1958 shows the 2-3/4 inch axles in it.
The 460 was more common, lots of 460's wore mounted pickers and had the big axles. The one local seed corn co. Had 2-3 460's they picked with.
Interestingly enough, I used to live in Findlay Ohio.
Now I live in Robinson, Il, which is about 1/2 way between Indianapolis and St. Louis, slightly south of I-70.
