Char-lynn brackets for SMD
DanMD
Does anybody have the brackets for the Char-Lynn power steering pump that is run off the add on crank pulley for a Super MD? I've been told the brackets are different from the gas tractors. I don't know as I have never seen either. I'd like to buy these brackets or at least see them to make something up.
Thanks,
Dan
The brackets are way different between the Gas and Diesel engine. Here are a few pictures on a 400D that I parted a number of years ago. I'll have to look if I still may have the brackets.
Yep. looks like the one on my Stage II SMD- unfortunately, someone cut a hole in the hood for access to the reservoir...
Dan, I did some looking and I found the brackets for installing the powersteering pump on the gas start diesel engine. I'll take some pictures tomorrow and post them for you to see. charlieu
(quoted from post at 00:58:48 02/02/15) Dan, I did some looking and I found the brackets for installing the powersteering pump on the gas start diesel engine. I'll take some pictures tomorrow and post them for you to see. charlieu
Sounds good.
Thanks,
Dan
(quoted from post at 11:25:16 02/02/15)
Sounds good.
Thanks,
Dan
I cleaned up the brackets and primed them, I hope you are able to see how they are made.
Those look really good. Are you interested in selling them? I do appreciate the photos either way.
Thanks,
Dan
