badfarmallh
New User
OK guys looking for some words of wisdom here, I have a 1948 H. And I cant get it to stop surging under load, the linkage from the throttle lever to the gov housing is in good shape, I took all the play out of it, checked the stops on the gov. adjusted per the manual, the weights move freely, and the assembly slides back and forth. I see posts on here about fuel issues, so ... fortunately I have second H. I swapped carbs and the problem did not change at all. I really think I am missing some type of issue in the gov. I also have installed a rebuilt distributor, checked timing and advance, and everything seems to be working well. Id like any ideas, im out of both good and bad ones.
