Phil W in Michigan
I have a 695 tractor with mount o matic loader. It has been overheating after an hour under load. I was looking at the radiator and there is some heat exchanger infront of the radiator. It is probably 14 " talk and almost as wide as the radiator. The radiator fill is in the center top of the radiator and extends out the top through the hood.
Is that second heat exchanger an oil cooler? It almost looks like the tractor might have had a cab at one time as there is a rubber sealing strip on the hood in front of the operator station.
Any assistance would be appreciated.
Phil
Phil
