Tel-A-Depth.
L.Fure
My 340 has the fast hitch on it. It does have the Tel-a-depth lever on it, but it isn't hooked up to anything. The rod that goes from the seat to the control valve is missing. On the control valve it just has a short lever with a plastic handle. This will raise and lower the fast Fitch, but I would rather the Tel-a-depth worked. I wonder why this tractor has the Tel-a-depth parts on it and isn't hooked up? Where can I find the parts I'm missing?
probably because at one time the tel-a-depth valve broke and instead of fixing the valve it was replaced with a remote valve so now you have UP and DOWN and you have to be the tel-a-depth valve
I don't believe those parts are available from the CaseIH parts network any longer. I know that to be true for the 240 model and is probably the same story for the 340 as they were both produced concurrently. Your only present part source for those linkage items is from a salvage tractor I believe at this time, Hal.
