Lucas0522
Will a H oil pan fit a SH engine. The SH had a C164 in it and H had a C152, is the bore just larger in the SH or is the whole block different?
My TC-49 parts book shows a 363510R91 as the correct
Super H pan, but says it will work for a 45723DCX
which I suspect is the H pan, but I don't have an H
parts book.
If that's the case, they should swap.
(quoted from post at 10:50:35 01/27/15) Will a H oil pan fit a SH engine. The SH had a C164 in it and H had a C152, is the bore just larger in the SH or is the whole block different?
The bore is larger in the C164 than it is in the 152. Everything else is the same.
Only difference in pans is a 3/4 pipe plug drain in one type and a hex head 7/8 SAE fine thread plug with washer in yours. Don't remember when the change happened without looking. late H tractors probably have the SAE plug.
