farm all h question
Brendon Warren
So how do you go about removing the steering shaft
on a Farm all H so I can pull the radiator? I can't
put my hands on my book.
There is a woodruff key at the steering ujoint. There is collar lock just in front of the steering post, loosen that so you can pull the steering rod back towards the seat.
that removes the rear part of the shaft, front is super simple, turn the shaft counter clockwise til is spins out. If I remember correctly.
Take cap off of steering bolster, pretty obvious which cap it is. Loosen the bolt at the knuckle, turn steering when until shaft comes out of front bolster. Catch key so you wont lose. No need to move the collar at the steering wheel end.
Early H tractors used a heavy washer rather than a Woodruff key. On those tractors the knuckle bolt must be removed and not just loosened.
