NFE Wheel bolts for 300
RalphWD45
I bought a narrow front end, for my 300 tractor, and the 6 wheel bolts didn't come with it, that holds the rim, to the cast center. They are mighty big holes, may be 3/4 inch ? I looked on YT parts, and did not see any offered. Are these special bolts? maybe fine thread? Where do I order them? Ralph
It takes a 5/8 x 2 3/4 fine thread bolt, nut, flat washer & lock washer. Use at least grade 5 bolts ( grade 8 would be even better. I have grade 5 in my 2 h's, one has a lift on front and have never broken one. Be sure to keep them tight.
Thanks Dave! I will run down to Olympia, to Tacoma Screw, and get them tomarrow. I think I will go with grade #8.
