roy prins
I have a F-20 that doesnt like to fire on number 2 and 3 -- the spark is very week on them and hot on 1 and 4 -- changed wires around and no difference -do you fellas think it is the cap like I do?
very well could be. You do know that the brushes are spring loaded? That would be something to check. I don't think new caps are available.
I have another mag that i could bolt on but is a different kind and only two bolts line up plus the timing lever doesnt hook up -- might be worth a try
make sure you have them in the right order - clockwise as viewed from the driver's seat. In CCW order, #1 and #4 w will fire at the correct time and the engine will run.
Yes, from experience!
