Re: First post, Question about a super A
uh, not sure what happened but the post got split into somehow.
I got my tractor apart for a clutch and the guide sleeve is gone for the most part except for a paper thin piece left that is stuck in the bearing carrier. I see the sleeve in the diagram but i dont see a way for it to bolt on. how does the sleeve attach to the housing or does it? Also where do i get a new guide sleeve i don't see them available on YT or the other places. The closes IH dealer is 3 hours away.
This is my first farmall I am just trying to figure out how the thing is supposed to be put together
The tube is a pressed fit then you need the carrierand bearing and the yoke is sprung and bent. Should be able to find parts at a salvage yd removing the tube can be tricky so it doesent get bent. The spring that pulls back the fork also is missing but hot that important.
