International Red Dimond 372
I have a 6 cylinder set NOS of pistons and sleeves for a IH gas truck engine. The part number on the boxes is 213443R91, and the number on the piston is 212728R1 My e-mail is open. Charlie U
4 3/8 is the size of my new pistons. I'll take my camera to the shop and get a few pictures for you to see. Do you have any numbers on your old pistons? Charlie U
Dewy,
A used car/truck dealer in Reedsburg, Wi had a good IH pickup last summer. I can check for you if you want to know the details. It had a V8 engine and I think automatic.
LA in WI
Here are a few pictures of the pistons and sleeves that I have. charlieu
Ok the numbers on the side of the piston is 4064
the numbers on the top of the piston is 213205-R1 735
CAM Z23
what does it measure from top of rist pin to top of piston mine is 2.056
Thanks
Well, my piston measures 1.645 from top of pin to top of piston. Also the number on the top of the piston is 212728R1. I did some research and the RD 372, 406, & 450 engine all use the 4.375 bore and a different length of stroke to get more CID. The pistons I have must fit a 406 or 450 engine. Sooner or later I'll fine what engine these piston will fit.
(quoted from post at 17:20:25 01/24/15) Well, my piston measures 1.645 from top of pin to top of piston. Also the number on the top of the piston is 212728R1. I did some research and the RD 372, 406, & 450 engine all use the 4.375 bore and a different length of stroke to get more CID. The pistons I have must fit a 406 or 450 engine. Sooner or later I'll fine what engine these piston will fit.
There was a 401 to would you be interested in selling one liner and piston?
I have 6 sleeve and pistons, that's a whole set for an engine rebuild, so I would only consider selling one cylinder assembly, if the $$ was high enough.
