super MTA diesel
Can I prime the diesel filters after replacing by just running tractor on gas with diesel throttle cracked open ? I am assuming the charge pump will pump with engine running on gas. Also what oil is used in the LPTO housing?
Open the water trap vent and the rear filter vent with tank valve open. When fuel comes out without air close and start tractor on gas. Vent front filter when clear close vent and if more venting is needed at the injectors, open throttle some while running on gas. Hytran or 10 weight engine oil in PTO. Probably better use hytran or equal in PTO because if the PTO input seal leaks any transmission oil and PTO oil will mix.
(quoted from post at 16:31:50 01/20/15) Can I prime the diesel filters after replacing by just running tractor on gas with diesel throttle cracked open ? I am assuming the charge pump will pump with engine running on gas. Also what oil is used in the LPTO housing?
no it wont happen. have to run it on gas and maually bleed the filters. primary first then secondary.
hytran.
