300 two way hyds??????
I have a friend who put a loader on a 300, its all hyd. he is having trouble because he only gets one way hyds on the bucket and the boom, he is using the outlets on both sides of the tractor. one side for the bucket and the other side for the boom, the bucket will curl up but settle back down, he cant put down pressure on the boom, it is acting like it is one way hyds, whats the problem, cylinders have all been rebuilt. any help would be appreciated. I havent seen it so dont know much more about it. thanks
If I recall correctly, those hydraulics can be used as either 2way or 1way. Under the hood there are levers on back side of the hydraulic lever block to switch it.
If it is a Farmall 300 you take right hood off and you will see on top of the hyd valves that you can turn the adjuster to single or double action. There is a roll pin to limit the movement each way, S or D. If a International 300 (utility) the valve are right in the open but same deal.
