standard drawbar secondary braces
Anyone have a photo of how 368392R1 and 368391R1 attach to the drawbar of 300, 400, 450, 460, 560 tractors.
The schematics show them as auxilary braces for use on standard drawbars when using the bolt on plate for pto implement use.
I think the more I look at the schematics, they
must bolt to the smaller piece that attaches to
the bolt on drawbar pad i.e. the drawbar pad goes
backwards to extend the distance for the pto shaft
but the smaller piece bolts onto the bottom of the
pad and runs crossways the pad. The small piece
has what looks like three holes middle small hole
bolts to pad and the other outboard holes are for
aux braces.
Does any of that make sense?? I still would like
to see photo of one attached.
I have the braces just trying to figure out how it
works.
You got it. Cross plate attaches to the extension plate. Support rods attach to cross plate and bolt to the regular drawbar brace top mounting bolts. Think you need the drawbar height close to the standard height for PTO work to get the rod holes to line up.
