Lucid
I saw your Demo C with 220 planter in the gallery. Would you have more/larger pics of that planter? I need to make the marker arms & paint.
Thanks
That helps a lot! Figured the marker arm rod went into the frame like that. I have the small rod link attached to the front mount part, but not the long rod link.
I bought a 2C-220 manual, but mine is got to be the C-220 (really a 221/222 not checkrow). Those parts are different between models.
If you have more pics, I sure would like to see them.
Thank you.
Oldiron29, can you send me an email vintage.farmall at gmail dot com? I could use some part measurements on this planter. Thanks ~Eric
