sony224422
I got this tractor after it had been sitting for years. Long story short, it needs braking help. I have taken it apart a little bit and so far I have found that the passenger side (long axle) side seems to be free and working, and will return to where it's supposed to with a new spring. The drivers side is really had to move but will with help pulling the pedal back. I can't see where exactly it's binding unless it's the actual band. Is it possible for it to bind there or is it more likely in the pedal assembly? It's only 8 degrees out so I haven't been looking at it as much. Thanks for any help
