Fit 2 Farmall H's in 10' x 15' storage?
I'm looking at getting a storage facility near where we have all our tractor club events. Does anyone know if a Farmall H and a second narrow front maybe a M or 300 can fit in a 10' x 15' storage space? I'm thinking an H is about 11' long, two narrow fronts with engines side by side. I good indication might be if anyone has fit two narrow front tractors on a car hauler that might be 8' x 16'.
If the tires and wheels were out wide and the front of tractors will squeeze between rear wheels and brakes clutch pedal ETC. You mite do it. If you can't get rear tractor tires past the front of a tractor, don't think you can.
Swinging drawbar or a drawbar plate may take up room also.
we haul two m's on a eighteen foot trailer. your width in no problem but you are a little short on length at fifteen feet.
Was curious enough to measure a H with 12.4 rears on 10 inch rims, wheels dished out and about as close in as they will go in on axle. If 10 wide on inside it looks like 2 that size would go if the front end is angled toward the wall 3 to 6 inches when backed in. But a 300 is 3 inches longer and axles stick out more with wheels in on axle. Didn't check a M, but they are wider from outside axle housing end to end than the others.
I have a 560 narrow front and a smta NF "spooned" in a 10' wide barn stall, but with them both diagonal in there it takes most of the 20' stall length to hold them. --Lee
the top deck of my semi trailer is 8 feet wide and 14 feet long. I can fit two narrow front tractors on it easy. you should have no problem
WEnt out to barn and measured my "H". If I got this figgered out right....
WITH 3-POINT HITCH
OAL = 12' 3", and the distance from back of hitch ball to front of rear tire 6' 2". Total = 18' 5" if parked front tires bumped up to rear tire. No go.
WITHOUT 3-POINT HITCH - OAL = 10' 8", rear tire diameter = 4' 11", total = 15' 7". Nope, I doubt it if would fit.
Maybe if you got a running start at it..
