Farmall M Repair Phoenix AZ
Bob85355
Neighbor bought an M and it has problems in the fuel system. Neither he nor I are competent to diagnose or repair the problem. Asking for info on Farmall M repair person in the greater Phoenix area; includes Glendale, Surprise, Peoria, Mesa, Tempe, Buckeye.
TIA
Bob
Get a quart glass jar. Open the valve on the sediment jar. ( If there is black residue in bowl clean that first)
Open the drain valve or plug at bottom of carb. Catch a jar full. If very little or very slow flow, problem is above carb. If good flow problem is in carb.
What did the seller have to say? Would he be willing to help?
You didn't mention AJ, If you were reasonably close I would come and take a look, I spent a lot of time on a M in the 60's! And I am going through tractor withdrawal, I miss them!
