M Farmall front wheel bearings
Mtractor
I have a Swhartz wide front the was on a M on the tag it says IHC M serial number 844761. I did not get any hubs with it but have found a narrow front that was on a M it has the 3 bolt type wheels. I tried to get the bearings out and they are froze to the spindle on both of them . I need a set of bearings so what part number do I ask for? My local dealer was no help at all. Thanks
Beware,alot/most if not all of those M wide fronts(factory/aftermarket)used the H hub/bearings.And some have the newer 6 bolt hub.Also different.You really need to get it apart before you buy (the wrong) parts.An M uses a much bigger hub/bearing than an H.
See if you can find a casting number on the wheels, like 4 numbers ending in D?. Measure the diameter of the Swartz spindles at both bearing locations. With that info it an be decided what bearings you need for the wheel and if they also work on the Swartz spindle.
