High gear not working
Got a B414 diesel.
Was plowing snow when tractor quit driving.
Engine runs fine but now it only runs in low gear.
When I put it in high gear and put it in first or reverse and lift clutch nothing happens put it in low gear and it will move.
Thought that therefore it would not be the clutch.
Any ideas??
Do I understand the entire high range is out? If so
it could be a broke gear or bad shifting fork , I
had a 424 same tractor behind engine , it broke and
I have never fixed it .
(quoted from post at 18:28:37 01/11/15) Do I understand the entire high range is out? If so
Yes that is correct entire high gear is out.
