Sleeve interchangeability M-MD
DeltaRed
does anypne know if a 4" sleeve from an M will fit an MD?One sleeve is cracked.I'm thinking of just replaceing the bad sleeve and reassembleing the tractor.
Nope
May not be a every time thing on a MD, but if one sleeve comes out harder than the rest. I seem to find a crack in the block cylinder wall on that cylinder.
Delta,
A Regular M Gas Sleeve Will Not Work Period
Last I checked you could buy a new 4" sleeve I believe threw case-ih for $160-180
Otheriwse Try Glen 402-986-1352 he may have a nos cheaper great guy to deal with.
IF you find a sleeve cracked in a M D - 450 and the crack runs up and down and usually on #2 or #3 you can almost bet that there is a crack in the cylinder wall behind the sleeve. If so don't panic just bore the block and install a repair sleeve and bore to take the standard sleeve .
Check on ebay, if not I just bought 2 short blocks one is a md the other is a smd. Once I get them home I will see what the sleeves look like may be able to help you out. Don't give up on the old girl yet. Jim.
