450 brakelock
Farmaller
Hi all, and Merry Christmas, I was wondering if someone could post a picture of a brakelock and lever so I can make one possibly, I have the small bracket to hold pull up lever, but that's all that there. many thanks
caseih.com, page to parts and search for parts by model then select the diagram for the parts you are missing. The pictures there will help. Jim
I have the lock plate on both of my 400s. It is nice to have but it isn't perfect. A PO had a dog chain attached to the latch and the other end was looped around the headlight extension tube. Probably would work as well as what you are looking for.
SDE
Don't think you can tell enough by the picture to make a original type one. But here's a picture.
Merry Xmas
Made one for my H, and it works but you have to be careful. I just welded a 1-inch x 1-inch little tab to the foot-lock lever, just aft of the pivot point. You just kick it with your heel as you depress brakes. Works great, locks great, you just have to be careful not to lock brakes when you are ordinarily just braking.
