Cub Super A Rear Wheel Weights
I do believe they will fit. I am sure I have seen a cub or two with the super A weights installed. The main difference is the super A weight has a larger diameter Center to accommodate the A wheel bolts. For that reason the cub weights with the smaller diameter center hole does'nt fit on the Super A properly.
Dan R
Bolt holes don't quite line up and otherwise they don't fit very nicely. But with the right bolts, the A weights can be used on a Cub.
cub rear weight bolts, needed tightening. grandson was turning the wrench. i told him to tighten them good. twisted head off of bolt. ha ha ha
gonna be a bit of a problem to remove the broken bolts. sigh
They are not a perfect fit but they can be mounted. As Jim says the bolt holes don't quite line up.
