International Harvester nos cast Iorn parts
Oliver2655
New User
Is there a way to look up parts stamped IHC with part numbers. I bought a truck load of new old stock parts and trying to find out what I have. They are all cast iron. Thanks
No info exists that I know of online from CIH for people to look up what specific machine a part is used on.
Type a part number into google. Sometimes you'll get lucky.
You'll likely need a where-used/master parts index microfiche set as old as the parts are as possible. Newer sets don't show long-obsoleted parts.
There were tractor parts books until the early 60's that identified what part number fit what tractor. There should have been equipment parts book with similar info, too.
Otherwise you'll need a room full of parts books and keep going through them until you find what machine each piece is used on.
Some stuff is easy to narrow down visually, some not so much so. If you dive into this, you'll get a feel via certain part number schemes what types of machines some of the older parts were used on, but usually you'll need more info to go from there.
AG
Hello, Please email a list of some of your parts
numbers I have a 1941 parts price list that list
the numbers and tells me what machine they were
used on, then I know what parts book to go to to
see what years it was used and on what machine,
most u prefix parts are corn picker parts I have
found a lot of the McCormick Deering Horse Drawn
corn picker from the late teens to the early 20's
in pile that I have, M prefix is mowers and
Harvester Threshers, N prefix Drills. Where are
you located and what color are the parts?
Kevin
