200 pinion gear removal
dewy
when using 3jaw puller.would you leave bolt head ,no washer, in so puller shaft doesnt go into hole for bolt .or should i use something else.....thanks dewy
I learned to use a small hex nut underneath the point of the puller shaft. Portable centering hole.
(quoted from post at 08:02:59 12/18/14) I learned to use a small hex nut underneath the point of the puller shaft. Portable centering hole.
f you put a drop of oil on the point of the puller and keep the back side of the nut dry, it pretty well insures that the nut won't rotate. That helps keep it centered.
