farmall 340 engine rebuild
R&W
i am thinking of buying an engine rebuild for my farmall 340 gas from this website. has anyone done this? does anyone know what kind of pistons come with it(dome or flat)? my 340 runs 60 psi and if i put oil in the cylinders it goes up to 120 psi.
Basic In-Frame Engine Kit - Made by TISCO. In Frame Engine Kit, For models 330 & 340 up to SN# 100500. (C135 CID 4-cyl Gas, 3 1/4 inch standard bore) For tractors with stepped head pistons)Kit contains complete sleeve and piston kit with rings, pins and retainers, valve grind gasket set and pan gasket. (Part No: BIFH1165)
There have been very few complaints in the years I have been on the Forum. The parts asn prices are as god as they get. Jim
Can you even get fire crater pistons anymore?
Also what are we talking about here, 1-2HP maybe? You won't even notice the difference.
