farmall200 pto drive gear removal
dewy
took out pto assembly ,,shaft was bent ..changed with new to me
pto assembly,,counted teeth on gear on back of shaft 49
teeth,,noticed one broke on new to me assembly... how do you get
gear off pto shaft..took bolt out...can see keyway grove in
shaft..how do i remove ....thanks yall.....dewy
You will need a puller (3 jaw)
This gear?
Yep! That is what I used. I pressed the pinion on and left off that part behind it. Had to pull it off and start again.
