Re: F20 Electric Start
F-Dean
The electric starter does not add any difficulty to restoring it. Take the starter motor to a starter repair shop for rebuilding while you restore the F-20. The most complicated thing you will encounter is a choke rod that you can reach from the seat!
Note that there is not any "IHC" stamped in the bell housing.
one thing that makes it difficult is the bump in the bellhousing for the starter wont fit between the framerails if you want to pull the motor out or put it back in. you have to partially take off the left side framerail
