Farmall M starter switch
Hattrick
Can anyone provide me a good source for a Farmall M starter switch? I ordered one off of ebay and the switch is a little smaller than the original and the logs on the back are smaller than the original. I am wondering if all of the replacements are this way or whether there is a good source for the correct one. The parts listed on this site as well as Stieners does not give me the specs. Thanks for your help.
After burning up 2 of those cheap switches on my Super M I mounted a Ford type car solenoid behind the rear gas tank support and wired the switch to just engage the solenoid, works good, also made the tractor 12 volts at same time.
I would bet that the only really good one you'll buy today is a new old stock Delco-Remy one. Early aftermarket ones (Standard, Blue Streak, Niehoff, etc.) may be ok if you stumble upon one, too.
AG
I solved the problem by moving the starter button higher up on the light post using an older style starter bracket.
(quoted from post at 12:10:01 12/13/14)
(quoted from post at 12:11:54 12/13/14) I will get in touch with C&G as they should have them then. Thanks
idn't C&G drop the IH line?
The other dealers around here got a parts contract for X years after CNH dropped them.
