Swhartz wide front hubs
Mtractor
I have a Swhartz wide front with out hubs will my original IH
hubs fit it? It is on a super h Farmall . Thanks if not what size
hubs do I need?
Really it depends on what spindles it has.
IIRC the H/M spindle size is different than the standard 6-bolt implement hub spindle.
If your front end came off an H, your wheels should just transfer over directly. Only way to know is to measure.
You are correct. the newer 6 bolt hub is different
from the H. the M is different still. However,the IH
6 bolt hub and the 8 bolt use the same 'spindle'.
