was a 1566 availible with a narrow front?
D17puller
Hey guys looking at a 1566 what do I look for on it to see if it has the correct front end to put a narrow front on it? Also was it even available this way? Thank you!
No narrow on a '15'. Only a very few 66 tractors had
the special bolster that would accomodate a narrow
front.Maybe you can find that special bolster at a
junkyard somewhere.........
Look at the front end. If you can see a hydraulic cylinder, then it does not have the correct bolster for a narrow front.
In order to install a narrow front end, the tractor needs to have a "wet" bolster, which has an internal hydraulic cylinder. BTW the bolster is the big cast chunk that holds the front frame rails together.
