684 ih with a loader
dacrabtree
New User
I have a 684 that has loader with a valve running off the remotes. I there a way to tie in to the hydraulics to run the valve that is simple and not cost a lot? Need to free up my remote.
(quoted from post at 21:31:57 12/08/14) I have a 684 that has loader with a valve running off the remotes. I there a way to tie in to the hydraulics to run the valve that is simple and not cost a lot? Need to free up my remote.
Hi hopefully my attached photo appears. There are two options:
1) purchase a power beyond adapter
2) With reference to left side of my photo, remove the seat and the deck plate, there will be a steel hydraulic line (item 39) running from top of remote hydraulic control valve to the draft control unit behind the seat. It is sort of a "L" shaped line. Remove this line and cap off the end at the draft control unit.
Connect the high pressure hydraulic input line from the FEL control valve to elbow of the remote control valve that hydraulic line (item 39) was removed from.
Connect the output line of the FEL control valve to the drain plug under the right rear axle.
You will have to purchase a cap for the draft control unit and a adapter for the return line to go into the drain plug under the axle plus some tye wraps to support the hydraulic hoses.
Hope this helps
JimB
