I have 656 with a combine motor in it and has a fuel shout selinoid in the carb and I want to do away with this carb. What carb would work on this tractor. I did have a john deere 3020 I bought a new carb for that did away with the shout off selinoid. But on a farmall I dont know which carb will work.
(quoted from post at 08:30:39 12/07/14) Keep your carb, remove the shut-off solenoid and install a a main fuel valve; this site sells them.
Exactly. It is the same fuel adjusting set-up as used on Farmall Hs and Ms.
Some of the shut off solenoids on my IH 6 cylinder engines have the solenoid tip nipped off, probably by a bolt cutter or a hacksaw. The solenoids tended to stick closed in colder weather. --Lee
I had a john deere 3020 that they did that too and it used more fuel than it should but with that I found an old school carb that was new for around 600 bucks
