got a cub, sounds like a j d running. pulled spark plugs and one had no gap at all.
read the compression and # 2 reads 0 , that is right zero.
valves are not stuck.
holding finger on the spark plug hole,there is little compression that i can feel. so piston is moving.
badly burned valves, or badly broken piston rings, or hole burned in top of piston.
what do you think?
what do you think?
