h wide front end
Kinda. The steering arm bolt pattern will be different. Not knowing which wide front manufacturer you have makes it hard to answer specifically.
I have a M factory IH wide front with tie rods out front on my H 2 things need to be done. If you have the set back plate it needs to be narrowed up for a H second is the steering arm the bolt pattern is different. If you bring them to a machine shop they can make them both work. I did mine myself on a bridgeport at my work.
