Manifold id? Pics
mschwartz
Hello here are a couple pics of the manifold I am trying to identify. Any thoughts ? Thanks, Mike
(quoted from post at 22:21:01 11/26/14) That manifold fits a Farmall regular. It is in parts book.
Yeah, rusticredacres said it while I was checking. It is the gasoline manifold for a Regular. There can't be many of them around.
Found an old post that listed the 414D casting number that I found on the head that is attached to the manifold as being from a farmall regular. Does that sound correct, I don't have a regular parts book to check.
Thank you, this head and manifold were part of the spare parts that came with the T20. Now I am starting to think that the original block threw a rod or suffered some other demise and they maybe used the regular block and original T20 head to put tractor back together. Love the mystery of solving 80 years history of repairs.
Hi folks, noticed the Regular manifold has the casting mark TW on it. I have a 1923 10-20 tractor with the same TW mark on all the castings and would I be right in thinking that was the marking for the Tractor Works. MJ
(quoted from post at 08:20:32 11/27/14) Must be a "Late" Regular - Note the upright exhaust. Could it also be an early F-20?
The parts book lists it as the gasoline manifold for a Farmall Regular. It is not listed in the F20 parts book but would probably fit it too.
