farmall 340 running bad
R&W
h ave a farmall 340 with a zenith universal carb 12522. what are the float and misxture screw adjustments suppost to be. thanks
(quoted from post at 16:23:14 11/26/14) h ave a farmall 340 with a zenith universal carb 12522. what are the float and misxture screw adjustments suppost to be. thanks
the float should sit level when you have top off carb and have bottom of it turned upside down.
set the main jet to 21/2 turns out and mixture 3/4-1 turn out. fine tune from there.
Throw the carb and get a M.S. carberator ,I don't
like those replacements I haven't had good luck with
them.
