Brian Luton
Hi all...
I have a Farmall Super A. Ran fine all season, sat for a bit and now it won't start. Checked plugs, etc. and had weak irregular spark. Decided everything was due and replaced plugs, wires, coil, cap and condenser. Now it still won't start and I have very irregular to non-existent spark at plugs. I have juice on both terminals of the coil.(negative is constant when switch is open and positive is pulsing with cranking) I do not have any juice at plug ends or on the center wire of the coil/distributor.(not sure if/when I should there) *pardon me being mostly electrically ignorant. : - /
Any thoughts, info, ideas much appreciated...
Thanks
Brian
Thanks
Brian
