Changing the hydraulic filter in 806
Nebraska Cowman
I was going to change mine one of these first nice days. Not today, too windy. I see the instructions with the filter says to bleed air out of the system as per the owners manual. Of course I have no manual. Is it as simple as cycling the lift arms up and down a few times?
I just read my manual, that what it says move the hitch up and down 10-12 times, and move your steering wheel left and right a few times! You can tell when it quits making that throaty noise, or sucking of oil noise, Then you shut it off, and check the fluid level again. Of course the warmer it is the day u change your hy tran, the quicker the process will be.
