Super h battery
Lucas0522
To any H owners, what brand of 12V battery do you use in your battery box. I can't seem to find one small enought to fit in mine. And I don't want to modify my box unless I have too.
What brand? I just use a small 12v car battey.Last
one I got was NAPA.Walmart sells em,as does anywhere
that sells automotive batterys. Measure case,or
better,take the case with you to the store.Then you
will know for sure.
If you have a Rural King close they have excellent prices on batteries. Look at the Grp 1 6 volt which would have been original on the shelf and then pick the one that is most similar in size in 12 volt is what I did.
I would recommend passing on any of the dual terminal batteries that are combo top post and side post. They do not last as long are at least none I have ever used from Walmart did. Plus the unused sideposts could arc on the metal battery box enclosure.
Someone on here stated that a good lawn tractor
battery will work. I don't know if it would spin a
super H over or not. They are certainly small
enough. AGM batteries put out a lot of amps for
their size too.
Both of my H's have interstate I-26 500 CCA 12 v batteries in them. Can't remember if I put a piece of wood under the btry to raise it a little bit so cables wouldn't hang on the box or not.
Did put a piece of foam rubber on top of + post so it wouldn't short out on the lid.
I use a Group # 65 Die Hard GOLD in my battery box seat base on my '54 Super H. It's the same battery that would go in my '96 Ford diesel pickup. My Super H plows snow in winter... has to start!
Well yeah, the under-seat battery box on the Stage II is way huge-er than the side mounted box on the more common Stage I.
All you got room for in that side mounted box is a Group 1 6V or a Group 26 12V.
