sc hydro problems
bass
the hydro lifts on my sc aint working. where is a good place to start troubleshooting the hydro system. I drained the old oil and replaced it. do i need to bleed the system
First place is right at the start. Hydralic pump.
Remove pump and check drive gear,key,ect.Is it
'makeing' engine oil? Then check the screen,makesure
it is not plugged.Need more info.
When I have done my oil in mine they are bad to get air in the
system. I parked my on a grade "my steep drive way" with its rear
higher than its nose and worked the levers forward and back a few
times till it burped itself. And like Delta said if that does not help it
the o ring in the pump my be bad and letting the hydraulic oil leak
into the crank case. Been there done that also.
