Wide Front End.
I have a chance to get a wide front off and 86 series tractor, wondering if it would fit a Farmall 560 the wide front I have on mine is and original IH 560 wide but don't turn sharp enough say when your raking hay.
Don't know for a fact but I think they are completely different animals. If you need a shorter turning radius be looking for an aftermarket wide front end.
The one off of the 86 series will not fit. If you want to shorten the turning radius up, get the top arms off of a 706 thru 1206 front end and put on it. They are shorter. Dont get the later kind that is held down with the large nut. Get the ones that pinch together like yours does now. Done this on several. Works out good.
