200 pto assembly..
am i posting a stupid question or not making my self clear....will a 240 utility tractors pto unit fit on a farmall 200...anybody out there ..at least tell me stupid question i can take it.. my pto shaft is bent on my 200...dewy
I couldn't answer those questions for certain without looking them up in the parts books, which you can do on the CaseIH web site.
Will they bolt up? almost certain yes.
Are they the same? I doubt it. The gear ratios are probably different. A 240 PTO will probably turn slow on a 200. Shift lever probably a different shape.
The question you didn't ask, the PTO shaft is probably the same in both PTO units.
Like Jim noted the shafts are the same 66184DA for both models but most likely something else is different if switching a complete unit model to model. A new 66184DA shaft is still available from CaseIH per Messicks on-line part search - pricey at around $185 but still available, Hal.
