Farmall 400/450 creeper gear
LarryM
I use a 450 with a Howard rotovator and sometimes would like to go slower than 1st gear but the torque does not hold back. Did they make creeper first gear for the 400/450 like they did for an M?
First gear from a 560 without high speed first and reverse will slow it down some. If you want it to go slower a 560 ring gear and a pinion shaft along with the low gear will get you in the creep range. But the R&P will slow all gears down.
