Farmallhal
Need part no. 460866R92 which is the front half (the shielded joint assembly which connects to the tractor's PTO shaft) of the PTO Drive Joint Assembly for an IH PTO driven hay rake. I located the correct back half at the Part Depot in Wisconsin but the front half has been very elusive. I've looked at various resources where difficult items can be found like Goggle, the Depot, and other on-line locations I am aware of without any success.
This item is used for Farmall 240, 340 and International 240, 340 Utility model tractors with 1 3/8" spline PTO shafts and the No. 11 IHC fast hitch side delivery hay rake and possible other applications. A serviceable used item would be satisfactory as well but will probably be unmarked as to a part number.
Any help in this matter will be sincerely and greatly appreciated and my email is open for contact, Hal.
