I have been working on this m for a while know. The tractor starts fine but misses on cylinder two. Once the tractor warms up the miss goes away. Heres what I have done:
manifold gasket- seemed to help some was planed
new plugs d21
new wires
new coil
went through the carb new carb to manifold gasket
points cap and rotor
adj valves
compression shows number two as the weakest cylinder but the range is 87 to 101
tractor has great power can plow all day and the miss never comes back governor is responsive. I have tried changing the gap on number two plug nothing seems to fix the problem. open to any ideas?
new plugs d21
new wires
new coil
adj valves
